D2 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
This is the nut for the negative post on the fuel pump and it looks like it has a nylon insert?
Here is my attempt at fixing my broken fuel pump stud. I was able to drill and tap the hole. I was able to get stainless steel screw, washer and nut for the repair. Unfortunately I wasn't able to get the hole drilled completely straight ![]() Got the head cut off and now I'm wonder if this is going to be a problem as this is not sitting straight and could cause a problem? Quote:
Yeah I know it doesn't need to be super tight for that nut. I guess I was super excited that I finally got everything I needed to start putting my new fuel pump back together and was in a hurry and over tighten that nut and it snapped ![]() Last edited by Audifan; 9th November 2020 at 09:49 PM. Reason: switched pictures to attachment |
Could you use a spring washer to help with the offset?
Can you just ignore the offset by tightening two nuts together on the bolt, keeping clear of the body, rather than tightening the nut down onto the body? Maybe with a locking washer of some sort.....
^ What he said. 🙂
Like one of these?
Exactly what I was thinking of, connector, standard washer, spring washer, nut?
After giving it some thought, I've decided not to risk using the repaired fuel pump and ordered a new one. As the saying goes, live and learn.
Thats a nyloc - the insert stops it loosening from vibration.
