Front or back? I've got the front driver's side wheel off and can't see a black box....
It must be hard to find as - following earlier thread - I asked my garage to check it before last winter. They couldn't find it and so didn't do it, but did clear scuttle drains etc.
D2 FL Q 2.8 V6 2002 Taxi(?) spec - no heated seats headlight washers etc. D2 PF Q 2.5 tdi LHD rear blinds and heated rear seats, Bose, 5 speed Tip, Servotronic, Pioneer AVIC 333,333 km Murdered on a P&O ferry 2012. Cat3 write off |
Found a black box above the battery in the boot, but everything is like new in there.. Put a 10mm socket on and tightened each connection up - but I suspect that's not what I'm looking for is it?
BTW - the battery has 12.25 volts across it - is that OK? Still, off-side front wheel is now very clean! Last edited by The_Laird; 30th October 2010 at 12:03 PM. |
![]() ![]() This photo shows the brown earth wire left of the socket ratchet. The purple connector is next to the battery connection box. The schematic
Silly Q... But was this maybe moved on the FL model?
The schematic is from a 2002 S8.
Found it! Just off to remove and clean - thanks!
Presumably it's just the earth taht needs cleaning up? |
