Old 30th October 2010, 11:27 AM
christhompson's Avatar
It must be hard to find as - following earlier thread - I asked my garage to check it before last winter. They couldn't find it and so didn't do it, but did clear scuttle drains etc.
Old 30th October 2010, 12:00 PM
Found a black box above the battery in the boot, but everything is like new in there.. Put a 10mm socket on and tightened each connection up - but I suspect that's not what I'm looking for is it?
BTW - the battery has 12.25 volts across it - is that OK?
Still, off-side front wheel is now very clean!
Old 30th October 2010, 12:26 PM
This photo shows the brown earth wire left of the socket ratchet. The purple connector is next to the battery connection box.
The schematic
Old 30th October 2010, 12:34 PM
Silly Q... But was this maybe moved on the FL model?
Old 30th October 2010, 12:37 PM
The schematic is from a 2002 S8.
Old 30th October 2010, 12:46 PM
Found it! Just off to remove and clean - thanks!
Presumably it's just the earth taht needs cleaning up?
Old 30th October 2010, 01:58 PM
Well, that was pretty corroded! Blue-coloured crud all over the place. Now cleaned, vaselined and WD40'd (the earth connection as well!). Started a treat after that...just hope it carries on doing so.
THANKS LOADS for you help guys - don't know what I'd do without you. Beers on me for the March meet.
