I had both of my knock sensors replaced a while ago. One of the plugs had disintegrated just like yours so I suspect it's a common issue. From memory, the sensors weren't too expensive and came complete with new leads and plugs.
Yes, it is a common problem. Somehow Bosch managed to make the connectors from a plastic which doesn't survive the heat of an engine bay
![]() You can't just replace the connector unfortunately. Its a screened cable which is very difficult to work with. The connector colour denotes the cable length by the way. Tbh if taking the manifold off is not an option I would be inclined to go with Andrew's suggestion of an adhesive product to hold the connector together. Yes, it has a high risk of looking fairly awful, but thats really all you can do with the green one. The brown one is on the outside of the V though, behind the power steering pump, so that can be changed without too much difficulty. |
Normal "domestic" Araldite is nominally only rated up to 65C, but would probably be OK. I'd probably risk it on my own car.
Better to find a 2-part epoxy adhesive rated for a higher temperature as the engine bay will normally be over 110C; there are loads available, Araldite themselves have a huge range. Or look at UV-cured adhesives, again a wide choice. I've used Bondic which I think is OK up to 150C; it's also clear and easy to build up so can be tidy.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 30th June 2020 at 03:21 PM. |
Thank you for all your comments. I see my options might not be set in stone, especially since Mark had his replaced without any issues.
I won't try to remove the manifold myself, as that would end in disaster, I am sure ![]()
Johannes _________ Audi S8 -99, Pearlescent, Alcantara/silk napa leather, Burr walnut insert, Alcantara roof lining upper pack A8 32V engine ----- Jeep Grand Cherokee -98 |
Apart from the broken connector and an intermittent knock sensor fault, one of the reasons I decided to get the job done was because I had some oil leakage and fumes coming from under the inlet manifold (plus I wanted to fit a spare new manifold that I'd purchased some years ago). The leak was caused by a failed gasket on the cover that sits in the 'valley' of the Vee (whatever it's called?). If your valley cover gasket has never been changed, it's likely it'll be very oily and gunky under there like mine was, so it's probably worthwhile lifting the manifold off just to replace the gasket and remove all the gunk.
Mark,
How did you determine a knock sensor fault? Did it show on diagnostics, or did you have pinging? I ask, as I get pinging from the S8 under moderate load in 3rd gear acceleration (labouring engine). I also have cracking in at least one of the knock sensor plugs, and I've been wondering if one of them might be faulty? I only use 98RON and often add octane booster, especially for trips.
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
I didn't notice any pinging but that could just be because my exhaust is so damn loud! Plus it was just an intermittent fault, which flagged a fault code, but only very occasionally. Unfortunately I don't appear to have kept a record of the fault code but, IIRC, it quite unambiguously pointed to the knock sensors.
