Old 2nd August 2020, 06:28 PM
Default D3 digital speedo change to kph
I have changed digital speedo on the DIS from mph to kph for driving on continent by changing coding for region in instrument cluster but it's always just a temporary change. If I cycle ignition it is back to mph. The coding is saved and fuel usage stays in l/100km but the digital speedo always switches back to mph next time ignition is turned on.
Does anyone know how to make a permanent switch until I want to change it again as it is a bit of inconvenience to change the coding every time.
Old 2nd August 2020, 07:17 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Can this not be changed via MMI too? Seem to think I’ve done it that way once...
2007 Mini Cooper S R56
Old 3rd August 2020, 09:47 AM
I had a look around in MMI but cannot find anything, could be down to version and firmware.
Old 3rd August 2020, 11:15 AM
I have a distant memory that it only worked on FL clusters, possibly wide DIS based? I know I wouldn't make this work on my 2006
Old 3rd August 2020, 11:16 AM
See http://forum.a8parts.co.uk/showthrea...al+speedo+wide
Old 3rd August 2020, 11:30 AM
I already have wide cluster, I think the older non wide clusters does not show digital speed at all.
If I change region coding to Germany for example digital speedo change to km/h, next time I turn ignition on it's back to mph but fuel consumption is still in l/100km and odometer reading is still in km
Old 5th August 2020, 11:28 AM
Found it in the MMI in the end, no need to change coding.
It's in:
Setup
Settings (right top function button)
Measurement units
Old 5th August 2020, 11:51 AM
Yes, this... . I just bought a UK Q7 , that was living in France, and he'd changed it all to KMH. Very annoying, took me a while to figure out how to change it all back !
