Old 4th September 2020, 07:15 AM
As above, I'd assume clocked if the interior wear is greater than such a low mileage would indicate. Any 'mileage adjuster' that knows what they're doing will know where the actual mileage is saved and amend all values.
You might see some slight variations in individual modules, but not enough to pin down what it's actually done.
I'd be concerned that any servicing it's had will probably have been way beyond the correct intervals - but given the 'low mileage' has it got any stamps in the book? You can guarantee if it's been clocked, it will have been done just before an overdue service.....
An 8k interior should look like new, unless the original owner was seriously overweight and had a tendency to sit on the side bolsters to get in and out!
