Old 21st September 2020, 12:28 PM
homer simpson's Avatar
Is there anything like this for the D3 S8?
Old 21st September 2020, 12:39 PM
It was a factory option, but not in the UK brochure as we're not considered a cold climate.
The webasto heater was already present on the Diesels as its used to warm the coolant faster in cold weather to produce warm air in a reasonable time.
This isn't needed on the petrols, so the retrofit is quite a bit more complex as you need a petrol webasto heater first, and then the aux heater pump for the coolant.
Old 21st September 2020, 02:05 PM
Don't for get extra fuel line as well, not sure if the fuel pump is integrated in heater or if you need extra fuel pump too.
Old 21st September 2020, 02:20 PM
Good point, as the petrols heat up much quicker probably not required. Might just look at the heated windscreen retrofit that is still on my list
