![]() There must be a queue now for rear subframe mounts.... ![]()
I'm hoping that full rear setup that Ronin found recently is viable. I'll probably order a set after this one is done
![]() Back on its wheels for the first time in two months! No error codes either ![]() Went to attach the new plates and discovered the PO had glued the rear on with silicone which is a novel approach ![]() I mechanically removed as much as I could and have left it soaking in WD40 overnight so hopefully road test tomorrow. |
![]() ![]() Good to see it all back together MJ ![]()
