having a bit of a hunt for what can be tweaked OEM style i saw a thread where someone had swapped out a set of chrome switches from an S5 steering wheel.... well for once i had something in stock having had a spare wheel for my S5 from ages ago....
what we started with... and the switches... but bugger... first issue... steering wheel was from a manual car, so no flappy paddles. hmmmmm.... So i took one switch to bits, there is a tiny torx bit on the reverse. With that undone the front unclips from the rear case. Could i just swap the fascia over? nope, wouldn't clip in.... bugger... would i be lucky enough that i could swap the inner PCB boards from the chrome, to the none chrome..... yup...!!! woohoo I always have the engine running so i can rotate the wheel so the screws will be at 12 o'clock Do not disconnect the airbag with the engine running, or the ignition on...!!! to get the switches out you need to remove this trim piece, after you have removed the airbag (with ignition off). all inner gubbins swapped over and built back up and airbag back in and all now nice and chromey.... chrome window switches needed from an A3 8P Sportback next.... Last edited by 89forever; 14th August 2021 at 09:59 AM. |
