Old 2nd December 2020, 03:54 PM
Conquistador's Avatar
Would it get any hotter than a halogen bulb with no heat dissipation in the same headlamp unit though?
See pictures - it's mostly tucked away behind a fairing, so it doesn't have to be particularly pretty because it's not in a very prominent position.
Also attached a couple of pictures showing the dimensions of a standard halogen H7 versus the dimensions of the actual LED H7 that I have.
That would be most useful though if you find some spare time to play around with it. You can PM me your address if so
ID:	24759   Click image for larger version
ID:	24760   Click image for larger version
ID:	24761   Click image for larger version
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 2nd December 2020, 04:04 PM
Yes, the back of the LED unit will get hotter than a halogen as the halogen dissipates all its heat inside the reflector, whereas the LED will dissipate most of it out of said heatsink. Jsut how hot, I don't know. Maybe we can try a couple of versions and see how they behave.
I'll pm you later
