Old 30th December 2020, 10:56 AM
hunker7 hunker7 is offline
Default Space saver
Does anyone have space saver for their D2? Currently running 245/45/18 monoblocks, I have LPG tank in spare wheel well and I do nearly 2000 miles a month so would be good to have back-up that doesn't take up half the boot?
Old 30th December 2020, 11:11 AM
How about the inflatable spare from the C5 Allroad?
The tyre has a folding sidewall, so although its full width, its quite small diameter when not in use. You'd need to carry a tyre inflator of course.
Old 30th December 2020, 11:17 AM
Learn something new each day. Never seen one of them
Old 30th December 2020, 11:41 AM
Its a curious thing, done to make room for the air suspension stuff which necessitated a bulge in the spare wheel well. By 'quite small diameter', its actually probably about 19", but thats a lot less bulk than a full size spare.
I've not tried inflating it because I don't know whether it can be deflated again without having a vacuum pump.
Old 30th December 2020, 12:35 PM
Didn't think of that actually. Only 2.2% diameter difference which shouldn't hurt the quattro, and they're very cheap 16" should fit over the brakes?
They fold away themselves, no need for vacuum pump. It's very fascinating to watch it when it deflates
Old 30th December 2020, 12:48 PM
Presumably no problem with the rear brakes?
"Just" swap a rear to the front if it's a front that's blown and the front brakes are too big.
Don't know what A8 you have but my PF S8 would safely fit 17" wheels all round (never tried 16"), the FL one won't.
Old 30th December 2020, 01:18 PM
The Allroad has the same size tyres as the D2, so if the 2.2% difference is ok on the Allroad it'll be ok on the D2 as well
I didn't know they were 16" - I'd assumed 17". The larger-engined Allroads have the same HP2 caliper as the D2 A8, but on a 321mm disc (instead of 323mm) so in theory should be just fine. I might fish mine out of the back of the Allroad (the boot of which is currently full of 1/2 an S6 V8) and see if it fits one of the D2s
Old 30th December 2020, 02:43 PM
vagdream vagdream is offline
What 17" wheels were you using? I have been running winter rubber with 17" Avus wheels on my FL S8 over the past three winter seasons with no clearance issues.
________________
Cars:
2002 D2 S8 Aqua (gone but not forgotten)
1988 UR quattro
2003 A2 FSi Sport
2020 Seat Leon Cupra R ST Abt
1989 911 Carrera Cab
Couple of Mk1 Golf Gti's (in bits)
Old 30th December 2020, 02:55 PM
They were (long ago sold) 17" Avus wheels from I think an S4, correct offset for a D2 and fine on the PF.
The rims just cleared the FL front brakes by a mm or so but the balance weights did catch on the caliper.
I guess with differently-placed balance weights or thin spacers they might have worked, but I decided to use the 18" factory Avus for winter and FE 20's for summer..
Old 30th December 2020, 07:48 PM
If you could test fit that would be great help
Checked wheel spec on tyre calculator and seems like it should be just fine.
