Old 8th January 2021, 08:41 PM
Drivetrain time. No good it just being a nice place to sit - it needs to be driveable too so its in for an engine-out service
Due to more bodging by the aforementioned perpetrator, general corrosion and nastiness, it took 2 hours to get the front end off, most of which was taken up with the bumper since both main M12 bolts were seized and one just snapped in half! I can get the bumper off while still attached to the support brackets, but in this case general bodging and gorilla-ing of the bolts made it even more of an ordeal than usual.
I've bought a Gopro for making workshop videos, so here's 2 hours of fighting with it compressed in to 3 and a bit minutes:
https://youtu.be/uUYPe-gVGD4
Only one front panel bolt snapped which is a bonus I guess, although I still have both bumper bolts to deal with at some point. Luckily I bought a load of front panel hardware from Tradition a while back so no qualms about binning rusty hardware now.
This is where I got to by the end of the vid:
This thing is in a terrible state
This is a 2000, from when Xenon Plus were optional. It still has the original external ballasts, but has been retrofitted with the later integrated-ballast headlights.
Oh dear. What has happened here?
The perpetrator has replaced the original sealed connector with some repair wires and an unsealed connector, so of course moisture has got in and eaten the terminals
Not sure what to say about this next bodge...
Whiskey
Tango
Foxtrot
Both these abominations will be cut off and replaced with unmolested parts from a spare wiring harness.
End of play today - (almost) everything on the top removed, ready for underneath work tomorrow.
(the snub mount bracket is still attached because one of the bolts is rounded off - that needs cutting off, but Big Red is just out of shot so thats another job for tomorrow when she can be moved)
Brace yourselves for some extra-special bodging....
This is what the bumper support should look like:
This is the passenger side:
One ear has been deiberately cut off to allow it to clear the AC radiator
Just for interest, this is the collection of tools required to get this far:
ID:	25053   Click image for larger version
ID:	25054   Click image for larger version
ID:	25055   Click image for larger version
ID:	25056   Click image for larger version
ID:	25057   Click image for larger version
ID:	25058   Click image for larger version
ID:	25059   Click image for larger version
ID:	25060   Click image for larger version
ID:	25061   Click image for larger version
ID:	25063   Click image for larger version
ID:	25064   Click image for larger version
Old 9th January 2021, 08:51 AM
I know it's wrong but I was thinking the Benny Hill Chase theme while watching the video! I'm a bad person arn't I?
Old 9th January 2021, 10:57 AM
60 times normal speed, I think that's acceptable
Old 9th January 2021, 11:57 AM
Did you spot this bit where she plays along to the tune with a makeshift trombone?
Impressive!
Old 9th January 2021, 07:47 PM
Stupid PS cooler! That's not going back on
No video today as I forgot to take the Gopro mount so back to pictures.
It's had the front level sensor and arm fitted at some point recently. Its the wrong arm, obviously (FE version) Still, at least they tried...
Drain grommets are removed as usual
and just sitting next to the ABS pump, obviously
Cut the heads off the lower rear arm bolts, rather than cutting holes in the floor Thing is, the hole in the floor isn't even in the right place!
Tie rods came out, which is nice. Usually on a car in this state they are seized solid.
Everything simple disconnected, just held in by the top plate
Remove as an assembly - I'll break this down separately, although not much of it is going back on.
Bare, and now I can get to the PS pipes. And clean everything, obviously.
Grot everywhere.
Definitely the worst so far
It looks like the gearbox was dragged around on its sump when it went away to, or came back from, refurb. The pan is bent and distorted.
Shame to treat £3K of refurbished gearbox like this
Oil is leaking from everywhere
Everything in here is either seized, snapped, or loose
Snapped rivnuts are no big deal as they are easily replaced
This earth point is going to be a real stinker to drill out, upside down
The starter cable stud was pre-snapped. This'll get replaced by a rivnut.
The one front panel bolt which snapped
The heat shields are mashed up from the engine and / or gearbox being removed previously. I'll replace these studs.
The servotronic solenoid is looking very crusty, and the green verdigris hints as to why it is intermittent. The rack will need to come out to replace this, which is a shame as I didn't disconnect the steering column before putting the car on the lift
More grot from oil leaks
Its going to take some cleaning, this one...
ID:	25067   Click image for larger version
ID:	25068   Click image for larger version
ID:	25069   Click image for larger version
ID:	25070   Click image for larger version
ID:	25071   Click image for larger version
ID:	25072   Click image for larger version
ID:	25073   Click image for larger version
ID:	25074   Click image for larger version
ID:	25075   Click image for larger version
ID:	25077   Click image for larger version
ID:	25078   Click image for larger version
ID:	25079   Click image for larger version
ID:	25080   Click image for larger version
ID:	25081   Click image for larger version
ID:	25082   Click image for larger version
ID:	25083   Click image for larger version
ID:	25084   Click image for larger version
ID:	25085   Click image for larger version
ID:	25090   Click image for larger version
ID:	25091   Click image for larger version
ID:	25092   Click image for larger version
ID:	25093   Click image for larger version
Old 9th January 2021, 09:29 PM
RICKY D's Avatar
RICKY D RICKY D is offline
It looks like you have your work cut out on this one!
I have a real soft spot for a Murple so I’m looking forward to seeing this all clean and back to its former glory.
Old 9th January 2021, 10:51 PM
Stromaluski's Avatar
Glad to see work starting back up on this!
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
Old 9th January 2021, 10:50 PM
27litres's Avatar
27litres 27litres is offline
Aaah... I've got that in my head now! Thanks Mike!!
I've come to the realisation that it's so much easier to take the whole radiator support off the car for access. This video confirmed it.
When I did my timing belt last year, it was such a faf to edge myself into the front of the car with the support leaning off to the side because i kept the aircon radiator bolted to it...
Not to mention it took me two days to do what Michaela does in a few hours!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 9th January 2021, 11:04 PM
gninnam gninnam is offline
Timelaps
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 10th January 2021, 08:09 AM
This is one of those cases where it's easier to just remove the stuff than to try and work around it, the same as removing the driveshaft and suspension upright to do the power steering hoses. Sure, its possible to do with it in place, but its much more difficult.
In a case like this where everything was seized then its a struggle to get it apart the first time, but once it's all dealt with it'll be simple next time. The front end comes off my grey one in about ten minutes - the worst bit of the job is disconnecting the PS cooler which is annoying and messy but as I hinted earlier, thats not going back on this one as I will redesign it not to go through the front panel. In later models Audi changed it to connect from underneath so it can swing out of the way, so I shall do the same.
The AC rad just swings out of the way too.
With the front panel on, its harder to get tools straight on to things like the water pump and crank pulley bolts, where finesse is essential. If you round off one of those then the front is coming off anyway to fix it, so better to just remove it at the start
