hmm, I can see that the breather hoses are also a much better design than on 2,8 where it has those nasty corrugated plastic pipes that make it easy for debris to settle on to and crack after a few years...
Regarding the wrapping of the AQH to prevent dirt ingress, i see from the engine service manual that there's a set of engine bungs available (VAS 6122) but when i checked the price they were around 100$ a set!! And you would need a few a those MJ
![]() ![]() And, a question for you MJ - whats the differences between the AQH and AVP? I see that there's a slight difference in torque (430@3500rpm and 420@3400 respectively) ?
+1, beat me to it David...
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ![]() ![]() (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ![]() (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
Mechanically nothing as far as I can tell. It seems to be all about the shift from Euro 3 to Euro 4, and the consequent change from Bosch Motronic 7.1 on the AQH to 7.1.1 on the AVP. With that comes secondary O2 sensors, individual control of the cam timing, and a warning light if secondary air isn't working. They changed the software and so also changed the engine code. BCS is the American version of the same thing, again mechanically the same but with different emissions specs. Cylinder heads, pistons, cams etc all the same so the difference in output is likely down to software.
Ironically, while the FL2 S8 got all the new Euro 4 gear, its still actually rated Euro 3 whereas the FL2 3.7 and 4.2 did achieve Euro 4. Luckily for British FL2 S8 owners though, DVLA class all the FL2 V8s as Euro 4 ![]() David - funnily enough I have a few items from that engine bung set from the two brand new engines I use ![]() |
MJ, your next Mastermind question is this:
The AQH /BCS engines seem to matched with different gearbox IDs too. The AQH/BCS are attached to ECY (ZF Pt No 1058 020 013; Audi Pt No 01L 300 041S) whilst AVP/AYS are attached to FBG (always though that stood for "F*cking Big Gearbox) (ZF Pt No 1058 020 030; Audi Pt No 01L 300 042P) Why?
Software changes again. ECY and FBG are exactly the same hardware, but with differences in the user interface - ECY has PRND432, FBG has PRNDS. You can put an ECY gearbox in an FL2 in place of an FBG and it works just fine. Likewise, you can put an FBG control unit and shifter in an FL1 with an ECY to get PRNDS (which I have done in mine and Mike's), although early FL1 clusters don't display the gear selection in the LCD as they don't understand the CAN messages.
