  #33
Old 7th March 2021, 12:03 PM
again because i'm a tart and i like peace of mind i always like to sweep the master cylinder as i do the final bleed, this needs an assistant and she's not home until tomorrow.... so the final bleed will wait for her....
I am quite the opposite, I avoid full sweep, just do the pressure bleed. It seems lot of cars don't get regular brake fluid changes so the moisture in fluid causes either corrosion or crud build-up in the normally not swept area of master cylinder and when you do bleeding pressing brake cylinder all the way it either scratches the seals or picks up debris and you end up with leaking master cylinder seals or sticking cylinder that does not fully return.
