Old 30th March 2021, 08:48 PM
Originally Posted by jonnypym123 View Post
Hi guys does anyone know either the part number or where I can get the rear tail light bolt caps/cover?
I have a bit of a condensation freezing issue inside the car and think it might be coming through these as there all off in my car. Checked the carpets already near the hvac drain and the pipes are dry jist in case it was that.
Have you checked the drain channels down the sides of the boot opening? The ones that accumulate leaf debris and sycamore seeds for fun? They have a join in them (what a daft design) and mine looked like it would let water into the join. I sealed it with Gorilla glue just to be sure.
Old 12th April 2021, 08:37 PM
jonnypym123 jonnypym123 is offline
Hi Jimster that's another job I need to do clean the muck out of the channels kind of been putting it off haha. But your right worth tending to before it comes a problem. Since the leak from windscreen I lifted the carpet and it was full of mositure straight to the tip it went and a new one in. Worth checking seals every year isn't it
