Old 23rd April 2021, 02:19 PM
dangerdred dangerdred is offline
Thanks for the above replies. Do I need to disable Jacking Mode before lowering it onto axle stands, or/and will I need to calibrate the suspension afterwards?
Phantom Black 2008 A8 3.0 TDI SE ASB
Old 23rd April 2021, 03:01 PM
I think you'd need to disable it after loweing it on to the stands so that it settles at its normal ride height before you tighten the bolts.
Old 23rd April 2021, 03:10 PM
homer simpson's Avatar
Yes disable it after you have lowered the car. Just don't forget to re-able it before you lift the car back up to put the wheels back on
Old 23rd April 2021, 07:09 PM
S81 S81 is offline
're changing the bushes ,removing the arms is simple if the pinch bolts aren't seized,removing the old Bush's is simple ,I run a hole saw thru the rubber ,opened a hacksaw and put blade thru and reassembled saw and cut the sleeve and popped it out with a screwdriver,10 mins will take all 4 out ,now the fun part ,,i am lucky enough to have a neighbour with a 10 tonne press in his workshop which pressed them in very easy,the big issue was getting them to sit square to get them started ,we filed the leading edge by a mill or so just to help them start square as the arm is alu and the bush kept biting and going of square ,the edge we filled sits out of the arm so it shouldn't matter , 're loading the suspension i did more or less what mj had said ,thou i hadn't thought of disabling the Jack mode
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 29th April 2021, 08:44 PM
GH77 GH77 is offline
There's an ever-so-slight chamfer on one side of the arms. The bushes only go in without biting if you push them through from that chamfered side. Might not have been your issue but thought worth posting for others in the future to be aware of.
I discovered this when doing the D2 rear suspension bushes. When the steel covered bushes started chewing the aluminium . . . .
2000 FL A8 3.7 QS - Turned 21 years old on 15th March 2021. Ming Blue - 175k miles. I love having a 90's car worthy of 90L of 98 RON! If only they still did 4* fully leaded!
2009 A8 4.2 FSi LWB - Marine Blue - 164k miles. Extras? Too many to list. But I do like the Rear Seat Entertainment . . . . . .
477k miles to the moon and back. 238k to go and between them they'll have made it!
