Timing belt
Timing belt service is coming up so just piling up a list of things that I can do while front end is off. So far I have; timing belt kit, waterpump, radiator, valve cover gaskets and chain tensioner pads... maybe valley gasket and knock sensors (plugs are crumbling away)
Anything else worth doing while at it? |
The oil cooler pipe is made marginally easier by all that stuff being off, possibly the front crank seal, and the thermostat. Radiator thermo-switch while the radiator is off. You'll need new rubber mounts for the rad.
Genuine only for the thermostat, plus order a seal as it doesn't come with one. Remember to order the o-rings for the gearbox oil cooler lines. Aux belt and tensioners while you're in there. Probably also the fan pulley too as they're always a bit noisy by now. |
crank pulley seal £10 brand new from Audi. if it leaks all of what you are about to replace has to come off.
Thanks guys, are these the correct parts I'm looking at?
yes they are correct. additionally number 13 is a plastic piece that often naps and I hink you can get them made out of metal.
Best place to get the o rings? eBay lists them for £46 each
Remind me tomorrow and I will post you some I buy 100 at a time for pennies each.
Check and replace the snub mount while you're there too.
Otherwise very difficult, next to impossible, access to it. Snub mounts are often separated and need shims to reduce tension on the mount.
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived thanks to MJ Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
