Old 2nd December 2010, 05:43 PM
spinedoc
Guest
Posts: n/a
Default Adjusting headlights?
98 A8 with the HID's and the drivers side light is aimed too low. What is the procedure to aim the light? Thanks.
Also how do you remove the HID light? Someone installed a blueish kiddie looking one on the left and I'd like to put a stock bulb/unit on that side.
Old 3rd December 2010, 07:26 AM
2 white allen headed adjuster as per the picture.
The adjust up and down on the outside and side to side on the inside.
Old 6th December 2010, 11:48 AM
spinedoc
Guest
Posts: n/a
Thanks, I'm being told on other forums that the computer will just adjust them back to the way they were before and I need to go thru the vag com to reset them. Sounds like it may have to go thru my shop.
Old 6th December 2010, 11:59 AM
If you don't have Xenons, then there is no auto levelling system (usually) and they should be fine.
Old 6th December 2010, 08:15 PM
spinedoc
Guest
Posts: n/a
As mentioned they are the HID's.
Old 6th December 2010, 09:18 PM
I think the question is are they factory xenons or after market HIDs?
Factory xenons are self levelling and after market HIDs aren't.
However, both headlights are initially adjusted (aligned) the same. Just that the factory Xenons will self level with a heavy load in the rear.
Old 8th December 2010, 11:38 AM
spinedoc
Guest
Posts: n/a
I'm assuming they are factory Xenons from what I'm seeing, is there any way to tell. And if they are factory Xenons does that mean I cannot adjust them without the vag com?
Old 8th December 2010, 03:12 PM
As I have no acces to a factory fitted 8 at present can you take a picture from above and post it here so I can see what you have please?
Old 14th December 2010, 12:20 PM
spinedoc
Guest
Posts: n/a
Thanks for the help. Here are some pics of the lights.
ID:	1537   Click image for larger version
ID:	1538   Click image for larger version
Last edited by Conan_the_Librarian; 14th December 2010 at 12:46 PM. Reason: Embed Photo's
Old 14th December 2010, 12:26 PM
Certainly looks like factory Xenons.. Do you have the adjuster screws on the top?
