#31
Its rare to need to re-use the arms, so destroying them to get them out is not uncommon.
These days I tend to assume I will need to change both inner and outer tie rods in a D2 when doing control arms. The outer will usually be seized in to the upright and often in to the inner rod as well, so I remove the upright by sawing the tie rod end off and then separate the remains on the bench. |
#32
Have managed to get the drivers side done - found it a right bitch of a job tbh.
Is there any knack in getting the arch liner back in - I see the procedure mentioned in the pdf but in Rep-66 which I don't see in the downloads. EDIT: I now see that the arch liner push trim clips are not reusable as no matter what I try I can't get them to fit back in.
Phantom Black 2008 A8 3.0 TDI SE ASB Last edited by dangerdred; 14th May 2021 at 06:30 PM. |
#33
I bought a pk of them on ebay ,how did u get the tie rod out in the end
Audi S8 D3 07MY 5.2 V10 Daytona Grey With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
#34
Yeh, I'm after buying some of the rivet clips. I didn't get the tie-rod out in the end and I wasn't going to start cutting it like was suggested, so I got the arms out the conventional way by leveraging down the shock mounting plate after loosening the three bolts.
Phantom Black 2008 A8 3.0 TDI SE ASB |
#35
Hi all,
I am at the point where I need to replace all of my control arms (scrubbing tyres big time) and have found this thread very interesting. Two questions I hope you may be able to help me with. 1-Are Meyle products any good. I hear that they may not be of german quality?? 2- Bushings were mentioned earlier. Can anyone let me know where I can source these, other than Audi. I'm told that Lemforder is the place to go but in Aus it's a little difficult as they seem to deal with the trade only. Any advise greatly appreciated.
2006 A8 4.2 Ltr Silver Green 20" Factory Alloys |
#36
#37
Managed to get all Lemforder bushes through ZF here in Aus.
Your comments on ball joints are duly noted. Thanks for the reply.
