![]() Also, yoink! ![]() |
Current : 2005 A8 Sport 4.2 V8 D3 - LPG working! Previous : 1998 S8 PF 4.2 V8 D2 - Gearbox died ~120k 2002 S8 FL 4.2 40v V8 D2 Prins LPG - Engine valves met pistons ~230K Also : 1996 Jeep Grand Cherokee 4.0l (Post Apocalyptic makeover) 2003 Brabus Smart FourTwo (should sell) 2003 Mazda Rx8 2.3 (might sell) |
I was searching for the part on Google (or ebay can't remember). As I have Amazon Assistant add on installed on Chrome, it shows a pop up of what's available on Amazon. Strangely, I just tried it again and it bought up the same battery on Amazon for £110 lol.
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
Be slightly wary, the seller isn't in the UK and now we are not in the EU extra charges may apply.....
That said, they might not also ![]() |
I've not seen that happen with Amazon - I would assume they are registered for UK vat so its all covered, but also its well below the £135 import duty threshold
Still pending arrival.....at AMAZON.....I'm starting to feel the batteries are fictitious, well at THAT price anyway
Caved....bought the Tanya battery one. £105 all in with delivery tomorrow!
Varta H3 100Ah and 830A I'll probably keep the Amazon order open and see. It'd be useful for the Jeep and better than the old Audi battery!
Swapping it over was pretty easy. I hooked up a charger while i did it as with the -ve post it's pretty easy to do!
Guess i need to have a look at coding it next week. I've not got my lap top with my and I couldn't figure it out on ODB11 - Also need to work out the right code, but Hey!
A battery/cell can look the same but have different Ah capacities because the length of the plate varies. Sticking comparable batteries on a scale is normally the tell-tale - heavier battery = more lead = more puff. You will get this as the best comparison with identically sized Yuasa batteries. The better ranges are heavier - a 5000 series battery will weigh more than 3000 series battery. Both my Infiniti's were extremely power hungry and both had 5000 series Yuasa batteries in them fitted within days of purchase. I have a 5000 series in the D2 as well. +1 for Tanya batteries - highly recommended (or at least until Brexit as their shipping costs to NI are now horrendous)
Daily drive: 2016 Infiniti QX70.....a car that's even more complicated than my last Infiniti FX to modify ![]() Current 'Project': VW Crafter CR50 4 berth camper van Previous 'Projects': 2006 Subaru Legacy Spec 'B' 3.0R, 1994 Ex-MOD Land Rover Defender, now "civilianised". 2000 Audi S8 FL www.whall.co.uk |
Ah.....The joys of Battery Coding.
My old one was 4E0 915 105 A von VA0 1501170013 I found info here http://forum.a8parts.co.uk/showthread.php?p=152240 https://www.audisport-iberica.com/fo...r%C3%ADas-vag/ and details on the batteries date and so forth https://technoluxpro.com/en/stati/ra...vki-bosch.html The battery was varta H13 - 12v 100aAh 830A which *IS* a slightly different spec. Couldn't find a 100ah battery, so went on the low side with 95ah one, DK - The date was March 21 from the serial 4th digits, 139 , so x Y MM (Also the old code, Jan 05, so that was coded right when last changed!) I used 4EO915105DK VA0 1103270040 Seems to be accepted, will see if it alters anything???
