Old 25th July 2021, 09:38 PM
Default WITW - The PF Exxon Valdez!
I bought another one Yes, thats nine. No I don't have a problem hush now
(actually I have a serious storage problem so I need to sell some stuff)
Its a 1998 PF, which is actually the first PF I've owned. I don't even get them in the workshop much. It was registered to VAG UK for its first year so I think it may have been a demo or press car, and as such it has many toys including blinds, auto mirrors, alcantara seats, satnav, ski bag, solar roof, rear parking sensors, and headlight washers. Its been with the same owner for the last 10 years or so and done very little mileage in that time. He bailed on it when the steering rack sprung a leak, and I couldn't let it go for scrap so I jumped on it. Its getting the treatment over the next couple of weeks and I'm hoping to have it for sale at AITP - no pressure then!
Some interior pics - it is a really lovely place to sit, and I am rather fond of it already.
Walnut wood which is a bit average, but I have some myrtle on the way
Black headlining
The rear blind actually works!
Ski bag
Complete first aid kit!
It has the threaded inserts in the floor for the tunnel brace, but for some reason just plugged up. Not sure if this is factory or someone has removed it? It'll get one fitted anyway.
Power steering oil everywhere
Its had a gearbox rebuild within the last 10K, and for some reason they seem to have sandblasted the whole gearbox, so the sump is in a right state. I'll get this blasted and powdercoated.
At some point, presumably when the gearbox was removed, the boss for the heat shield and exhaust hanger was broken off Not sure how I'll fix this - I may need to swap the rear casing, or it might be possible to weld it in place
So much leaking oil even BP is considering an apology
More leaks
and more
The undertray hangers are rather smooshed
Oh, more oil
The usual detritus
Its not terrible on top but it has been sprayed with the crappy lacquer that car dealers used to use to make engine bays shiny for the hour the punter was looking at the car The nasty crap has gone yellow and ruined pretty much everything it touched
More oil leaks!
Five original Avus 1 wheels with centre caps These were actually the reason I bought the car since they are so rare. Even if the car turned out to be a lemon, it was worth buying just for the wheels. These are in for refurb while its on the lift
ID:	26764   Click image for larger version
ID:	26765   Click image for larger version
ID:	26766   Click image for larger version
ID:	26767   Click image for larger version
ID:	26768   Click image for larger version
ID:	26769   Click image for larger version
ID:	26770   Click image for larger version
ID:	26771   Click image for larger version
ID:	26772   Click image for larger version
ID:	26774   Click image for larger version
ID:	26775   Click image for larger version
ID:	26776   Click image for larger version
ID:	26777   Click image for larger version
ID:	26778   Click image for larger version
ID:	26779   Click image for larger version
ID:	26780   Click image for larger version
ID:	26781   Click image for larger version
ID:	26782   Click image for larger version
ID:	26784   Click image for larger version
ID:	26785   Click image for larger version
ID:	26786   Click image for larger version
ID:	26787   Click image for larger version
ID:	26788   Click image for larger version
ID:	26789   Click image for larger version
ID:	26790   Click image for larger version
ID:	26791   Click image for larger version
Old 25th July 2021, 09:49 PM
Audifan Audifan is offline
Nice save! I really like those Avus wheels! I would love to have a set of those wheels for myself. Oh nice alcantara sport seats, I wish my car have the alcantara.
Old 25th July 2021, 10:01 PM
RICKY D's Avatar
RICKY D RICKY D is offline
What a beauty that is
I’d love a PF in black with that spec.
Excellent purchase
Old 26th July 2021, 08:35 AM
homer simpson's Avatar
no pressure then!
I see what you did there
Old 26th July 2021, 11:31 AM
Are you sure you will be able to let this one go?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Audi S8 2002 FE Avus Silver / Extended Red Leather. https://forum.a8parts.co.uk//showthread.php?t=16187
Honda Jazz
Old 26th July 2021, 11:58 AM
Not sure at all! I fear I have may have bonded with it because its a lovely place to sit
I have come to the realisation that sitting in them is the critical first impression for me. If it is immediately cosseting and cosy like a D2 should be, I feel good about the car and have a tendency to keep it. If its stinky and minging and I have to put a lot of hours in to make it nice, I don't develop an attachment to it, hence why I almost scrapped the murple.
However, I can't keep this one. I have too many already and I have no need for it, no matter how nice it is
Old 26th July 2021, 04:03 PM
Question for those more knowledgeable than me on the PF: is the inlet manifold different between A8 (AEW / ABZ) and S8 (AHC)?
Etka isn't very clear as it calls it 'suction pipe with elbow' The AHC has a different suffix, but the same throttle body... Of course none of the number match anything on the actual manifold!
Old 26th July 2021, 07:37 PM
S81 S81 is offline
The d2,s are a bit like stray dogs to you i think ,(u haven't got the heart to turn them away ),good luck with the refurb ,will 200hrs ish do it ?
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 26th July 2021, 09:08 PM
Cats, but yes
200 is probably about right for this one since its in pretty nice condition apart from the leaks and the horrid car dealer lacquer, and it has all come apart reasonably well.
I started taking it apart in the middle of last week. First job - disconnect the steering column from the rack before it goes on the lift
Once it was on the lift I moved on to removing the suspension and discovered the brake pad warning cables have been cut and bypassed
The pinch bolts and tie rods came out without a fight, which was nice
Saturday now. Engine removal, starting from underneath. I mentioned that the heat shield bolt on the driver's side was snapped off - the passenger side bolt has been gorilla'd as well and I can't get it off. The heat shield was already broken on one side so I just snapped it off. More on this mess later.
The power steering fluid is pretty grim, which is weird considering how much it was leaking. I'd put half a litre in it just moving it around the place. This will all get cleaned and replaced though.
Front panel off. Its filthy in here.
The stubborn-pulley-getter-offer tool
Ta dah!
Magnets on the fuel lines
Ohhh dear....
Ready to come out
Coming out
Out
The grottiest engine bay I've encountered so far I think
Drivetrain on the pallet truck ready for disassembly
When the gearbox was done the cam position sensor was refitted with the cable sitting on the exhaust manifold instead of behind the heat shield! How it was still running is a mystery.
I don't have mounting brackets to fit the 32V for the splitting machine so I just supported the engine with the crane and rolled the gearbox off the back of it
Home-made crank locking tool I loosened the crank pulley bolt before putting it on the stand, since these things are so tight that with the engine on the stand I can't put enough torque on it to loosen the bolt without the stand falling over!
Separated
Engine on the stand ready for stripping and cleaning
ID:	26796   Click image for larger version
ID:	26797   Click image for larger version
ID:	26798   Click image for larger version
ID:	26799   Click image for larger version
ID:	26800   Click image for larger version
ID:	26801   Click image for larger version
ID:	26802   Click image for larger version
ID:	26803   Click image for larger version
ID:	26804   Click image for larger version
ID:	26806   Click image for larger version
ID:	26807   Click image for larger version
ID:	26808   Click image for larger version
ID:	26809   Click image for larger version
ID:	26810   Click image for larger version
ID:	26811   Click image for larger version
ID:	26812   Click image for larger version
ID:	26813   Click image for larger version
ID:	26814   Click image for larger version
ID:	26816   Click image for larger version
ID:	26817   Click image for larger version
Old 27th July 2021, 09:56 AM
I'm guessing the break pad sensor threw up a implausible signal fault and so they by-passed it?
