The power steering leak has ruined the rear right subframe bushes. At £50 each, I'd rather not replace eight of them, so I cut up a bad subframe to rescue the bushes from that instead.
The donor subframe was toast anyway Rescued used bushes in nice condition This one has been dissolved by the power steering oil The dirty bits are where the rubber was split Someone has damaged the access holes for the rear arm mount Some heat from the mapp torch and a little percussive maintenance and they're back in shape This is one of the reasons for the catastrophic oil leaks - the last time the timing belt was done the special o-rings on all the cam end-caps weren't replaced but just smeared with silicone. There are two sizes of these, and alas this small one is NLA so I'll be experimenting with traditional round-section o-rings to seal these up again. Luckily the larger ones are still available from Tradition. Cam locking tools kindly on loan from Prestige ![]() The oil leaks have contributed to the oil cooler pipe being completely destroyed Its as bad down on the block as Big Red was Cleans up ok though. |
"percussive maintenance" - the thing you do to cars when WD40 doesn't work
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ![]() ![]() (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ![]() (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
![]() Pleased to see that I’m not the only one that thinks that reclaiming perfectly good parts from an otherwise useless assembly is a reasonable thing to do…. Nick |
