Thanks MikkiJayne. I'd best have a look for water ingress then. But where is this electronics box?
I can confirm that the fault does not come when you move the lever. Only about 100 yards after you move off. The car has been here in warm, dry Bulgaria for a few months, but before that it stood outside in Scotland unused, for 18 months. There was some water ingress to the boot, caused by a perished bung, in the boot gutter side. Is there anything in the boot that could cause this? |
The electronics box is the black plastic lump at the base of the screen on the left. There are a bunch of philips screws holding the lid on which are almost certainly seized in place if it's sat for that long, but worth a try. The TCU sits at the top and is not water-tight, unlike the ECU, so has a tendency to be the first in line for condensation damage. Its a bit of a pain to get to, but if you can remove the connector its worth looking for corrosion there first and giving it a spray of WD40. Sometimes that will help it, but sometimes there is internal corrosion too. Have a look for my General Vod workshop thread - I show the process in there. That one got scrapped for a blown gearbox whereas in fact it was just water-borne deposits on the TCU pcb. I cleaned it with isopropyl alcohol and a toothbrush and let it try overnight and it worked perfectly ![]() Btw, I sell replacement boot grommets here: https://www.ebay.co.uk/itm/153918842338 ![]() |
Hi Mikki.
Ok, I'll have a look in that box for water etc. I need a couple of those grommets, so will buy as soon as I have a UK shipping address. We are in Bulgaria and shipping anything here from outside the EU is a pain. Sorry for late response, last night we had a major storm here and lightning must have struck the mast-thus no internet. I'm just relieved that its not 'curtains' mechanically for the box....yet. I really like this car. |
Ok. got the lid off and it's clear there has been moisture in there. very light rusting of steel parts, and typical alumium corrosion, but not much.
I take it the engine ECU is nearest the wing and gearbox item nearest the middle of the car? It is. Getrieb = transmission! Last edited by Simon Wallwork; 1st August 2021 at 02:50 PM. |
Oh dear.
Scooshed some WD-40 in there, and refixed the cover- seeing as the fault had gone away. Took it out on the road and not only is the fault back, but it also does it in tiptronic now too! I guess next step is remove the TCU and clean its insides? |
How the heck do u remove the TCU wiring connector???
Just picked up on this thread - 37 degrees in Langbank - really?
Unscrew the TCU bracket (two screws at the front) so that it can be lifted towards the front of the car, then unbolt the TCU from its bracket (4x M6 nuts). You may need to lift the ECU out to get the TCU wiring free.
