Originally Posted by ainarssems
Mr K
Battery in the key is for remote only. Transponder for immo works without battery. It gets power wireless from sender/receiver unit in the car.
Your other key does not work because it is either not coded into immo, is faulty or have a weaker signal and poor connection causing weaker signal not being read properly.
I had thought that the battery in the key might not be anything to do with the immo as the funny little plastic emergnecy key obviously has no power in it, and still works.
Thanks for the advice, i will have a play when the weather warms up. Any ideas where to start trying to fix it? Im guessing the immobiliser / cluster should be the first point of call? where is the transmitter/receiver, is that in the column?
Many thanks.
