Old 10th September 2021, 07:31 PM
Ronin Ronin is offline
Thanks for the above answers.
In that case I'll just treat the seals and lubricate the guides with silicone and get the car tinted with glass already on it.
Old 13th September 2021, 09:15 PM
Well I have them here... gonna clean and grease them up and hopefully its a one man job
My 2.8 will probably end up as the most upgraded example around and will be worth absolute peanuts, but hey, this is better than smoking
Old 14th September 2021, 08:10 AM
I hear you!
Old 19th September 2021, 08:17 PM
I've done drivers side front and rear doors so far and it hasn't been too difficult, it can be done by one person.
I'm astounded by how much detail has been put into the door cards, they have loads of self adhesive foam seals, places routed especially for wiring and each door seems to be hand numbered.
It takes a few attempts to align the window frames perfectly so that the door opens and closes correctly and seals.
The door seals themselves seem to be made out of very high quality rubber and all the little channels and clips it all fits into is just right.. My 21 plate Toyota seals look far worse than 20 year old audi ones.
Also there are different types of sound deadning material in the front and rear as if they properly experimented with what shape/size/material works best.
I haven't broken any door card clips yet
Name:	WhatsApp Image 2021-09-19 at 21.30.58 (1).jpeg
ID:	27228   Click image for larger version
Name:	WhatsApp Image 2021-09-19 at 21.30.58.jpeg
ID:	27229   Click image for larger version
Old 11th October 2021, 07:56 AM
Now for the triangular side windows...
Have any of you removed them?
Service manual shows rivets that have to be removed, but the windows I have don't have any holes etc for them and I don't want to start ripping stuff apart.. were rivets used just on pre facelifts cars?
Old 11th October 2021, 08:06 AM
Or the front door team didn't talk to the back door team and so they came up with completely different ideas, both of which are rubbish
The quarter windows unbolt from inside.
Remove:
Back seat (base and back)
Rear inner sill trim
D-pillar headlining trim
Outer aluminium trim
Both inner trims round the quarter glass
Then the glass can be removed
Are you tinting them while the doors are in bits?
Old 11th October 2021, 08:22 AM
Smile
Remove:
Ha! thanks for this. I think I will fit the windows and leave the trim off so that the tint man has better access and then put it all back together
