Old 23rd October 2021, 02:45 PM
projektzwo projektzwo is offline
At first I wanted to fit RNS-D, as the reason for changing the radio cassette unit is all about the looks and so I can play some CDs, but the I found out that the RNS-D navi plays only navigation CDs, not a music ones. But if it’s a real pain to fit a RNS-E then I’ll stick it RNS-D and a CD changer. Not really interested in using the TV and Navigation function on any of the RNS-E or RNS-D units, as I said it’s all about the look and the ability of playing music more easily…
Old 23rd October 2021, 02:50 PM
Ronin Ronin is offline
why not get a dedicated android unit then?
Old 23rd October 2021, 03:22 PM
Aside from the wiring, which will be non-trivial in a PF, the PF double-din facia is a different shape to both RNS-d and e units:
PF:
RNS-doorstop
Better off just fitting an aftermarket single-din media player tbh.
ID:	27367   Click image for larger version
Old 23rd October 2021, 05:16 PM
Maybe there's a different PF fascia then for the RNS?
My PF S8 definitely had a RNS-C and it's exactly the same size as an RNS-D.
The only way you can tell them apart from the front is that the RNS-C doesn't mention TV on the label on the bottom left button, you select it via a sub-menu if it's installed (as mine was).
Edit: I will correct myself. The RNS-C has the same size body but the fascia is rectangular, so you'd need to trim an RNS-D faceplate to fit a PF.
Attached photo demonstrates...…..
Old 23rd October 2021, 05:25 PM
PF:
RNS-doorstop
I’m really for the oem look, and there is no drama with finding the facia panel for my PF model, alredy found it and I found the RNS-D navi + CD Changer for £50 in like new condition. Never looked for any of these aftermarked navi’s or CD player but I’m very sceptical about the look. There is one Blaupunkt SQR 46 Bremen, but it’s £400 which is way too much for this unit.
Old 9th April 2023, 09:49 AM
Pcbbc Pcbbc is offline
Smile Finally RNSE support for A8 D2 cluster
Coming shortly to an RNSE and A8 D2 near you…
https://youtu.be/qxwLyRDTgxE
Old 9th April 2023, 04:05 PM
Ok, you have my attention...
If I'm reading your site correctly, you can make SDHC work on a 192 unit from a C5?
Old 9th April 2023, 04:25 PM
Yes, SDHC card support for 192 units and maps on SD card (either 192 or 193) with the feature pack.
You’ll need to wait for the upcoming beta for support for the D2 FIS display.
Old 9th April 2023, 04:37 PM
Ironically, I'm not bothered about the FIS display I am, however, interested in the RNSe as a media player with a video-in for an Android Auto device such as a Raspberry Pi (for some distant day in the future when you can buy them again) so it can be used with Google Maps. SDHC support makes that much more viable How it would work with the low-res mk1 unit I don't know, but its worth exploring.
Old 9th April 2023, 07:35 PM
You have my attention as well.
I vaguely thought about upgrading from RNS-D to RNS-E ages ago but it seemed somewhat pointless as the gains were offset by losses, but maybe no longer?
