I've got my subframes and fuel tank brackets ready for powder coating, I'll let you know how much it was so maybe we can compare to other parts of the country
Paul Gosport UK ________________________ Audi S8 2002 FE Avus Silver / Extended Red Leather. Daily Driver: BMW 3 series GT - Just more practical for my camping trips! |
It's stupidly expensive, I've paid £50 each for front and rear. If I can get mine done I can send you the one off my car and I'll keep the one off yours? I'm sure something can be worked out
![]() I am in South Wales every 3 weeks so can execute swap / pickup when suits.
That's cool if you get round to it sooner than me I'll just give it to you and once you have your old one back you can give it to me. I live 2mins off junction 32 of the m4
rear control arm bushes have appeared on autodoc at an affordable prices:
https://www.autodoc.co.uk/car-parts/oem/4d0505171l |
Interesting - thats the A6 bush which I have been using. Someone else has obviously also figured out it is compatible with the D2 and updated the listing
this is the type of corrosion i have been seeing on many Audi,s
mainly the scottish ones or been near the coast we have shot blasted 2 now off audi A2,s that we have been refurbing thank god the D3 has an alluminum one ![]()
Looking for the Holy Grail Audi .. 2018 VW Caravelle Executive T6 2010 A6-C6 3.0tdi LeMans Quattro |
I've been slowly replacing the rear subframe in my S8 due to rust issues on the original subframe. One thing I have figured out is that it was designed to be assembled outside the car and then installed into the car as a unit.
I put the bare subframe in and then started putting parts on it. There's quite a few bolts that you simply can't get to with a torque wrench once the subframe is in the car. Just in case that helps anybody.
-Andrew 1967 Bus 1980 Rabbit Pickup 1992 Corrado 2001 S8 2010 Jetta TDI Cup Edition |
#30
Yeah the upper control arms are not fun to access with it in the car. I've dropped a side at a time to deal with those in the past, but much easier to assemble it on the ground and then lift the whole thing in to place.
