Loose connection somewhere? I recall a thread a while back about a main power cable connection in one of the footwells which can overheat and fail and cause problems.
Rear batt pos cable was getting quite warm but have changed that,i think the main power feeds down driver side through footwell?
Junction box in footwell has good voltage before and after...
Swapped multiple body comfort and power modules but still no nearer a fix...modules begin shutting down causing a ton of errors loss of pas etc...
Left car with main dealer northampton vindis who cant find the issue,audi service is shockingly bad
Why haven't you posted a full unedited VCDS scan so others may make informed suggestions?
Way too many codes to decipher! The fault is somewhere in the low can wiring,left it with audi on the off chance their master tech may have experienced anything similar,all they can suggest is the battery is not oem even though its equivalent varta and coded
