Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
Yeah the B5 parts will hopefully be here on Saturday and I will post pics of how they fit
![]() Botang's grommet: |
We’d expect nothing less by now!
![]() Your perfection level has just gone up again! ![]()
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 Last edited by strummagnet; 21st February 2022 at 03:16 PM. |
No significant progress today as I have a migraine
![]() Botang's grommet fitted fine. Its probably watertight on its own, but I've covered it in seam sealer anyway. This is not the car on which to experiment with water ingress! New foam on the hvac inlet Hopefully I can put the engine back in tomorrow. |
with botang's hole I find it harder to photograph than to do work on it
Very true ^
![]() I put the engine back in this morning The A4 links arrived - top, compared to the D2 on the bottom. You can see the extra spacer they have and they fit perfectly ![]() Starter terminal box. I've taken to filling these with waxoyl as its waterproof but not as nasty as the thick grease the factory used. Put the washer bottle back in and tested for leaks. Of course it did leak, from the level sensing grommet on the windscreen washer pump, which they always do when disturbed, hence testing. I can not get this one to re-seal so I'll print a new grommet. Mostly back together. Suspension and front panel tomorrow. |
Oddly I find myself staring at the images of this engine for ages, thinking maybe office wall art?
![]() Is that expansion tank super cleaned like the screen wash reservoir? I have noticed in a few other posts the coolant is pink? I am beginning to think the garage that changed my water pump, which I supplied with the requisite amount of G12 coolant a few years back, didn't put the G12 in. The coolant is 'clear-ish' but starting to turn the tank brownish from the inside ![]()
