Old 21st February 2022, 03:25 PM
Ronin Ronin is offline
I got these - https://www.autodoc.co.uk/meyle/2118455
must be the wrong ones
Old 21st February 2022, 03:42 PM
No, general consensus was that they were the right ones and have been the part of use for suspension refresh. It is only MJ noting the offset in this thread that has challenged that.
The part numbers I gleaned were from this post (so apologies to MJ)
http://forum.a8parts.co.uk/showpost....7&postcount=44
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 21st February 2022, 04:07 PM
Yes, they were correct based on what we knew at the time. I've only discovered the offset on this car, and that was only because I assembled it all on the floor so had clear visibility of it and was able to get a direct comparison of the various bits.
We're probably going to find more like this as we need to find alternative sources for things. At least they aren't expensive
Old 21st February 2022, 08:10 PM
I got the strut back this afternoon with a tiny bead of weld on the formerly-smushed edge
A quick dress with the grinder and the bolt fits perfectly again
Mounted on the car again
I put a bunch more stuff back in but forgot to take any pictures. Hopefully brakes and front panel back on tomorrow and then I can fire it up
ID:	27936   Click image for larger version
ID:	27937   Click image for larger version
Old 23rd February 2022, 08:49 PM
Pretty caliper
New splash plates and bolts. The D2 bolts are NLA, but later models use an identical bolt with a slightly different number, because of course they do N90598804 for future reference.
Febi brake disk and hose, TRW pads, Apec fitting kit
New hose and clips obviously
This would have gone a lot better if I remembered to bring the other caliper from home Never mind - that can go on tomorrow.
ID:	27939   Click image for larger version
ID:	27940   Click image for larger version
ID:	27941   Click image for larger version
Old 24th February 2022, 03:46 PM
homer simpson's Avatar
Silly question, never used Febi brake discs on a car, how well do they fair? I'm looking for a set of discs and pads for a friend on his BMW (sorry) but Brembos which I usually fit on most cars are very expensive
Old 24th February 2022, 06:39 PM
roberto's Avatar
roberto roberto is offline
Default febi-bilstein i think, one of the biggest companys THYSSENKRUPP
ive used them before , spot on
get a price from thingy in germany cant remember
