#311
As a matter of interest When you say align the front end is that just to make the bumper/gaps align or is it something more / different
With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
#312
Yes, exactly that. The position of the front panel defines how the bonnet sits in relation to the wings and headlights so that needs setting first, then once that is all correct, the bumper can be adjusted to suit.
#313
That rear subframe looks pretty dreadful! Did this car live by the sea at some point? Reminds me of the state of my GL5 that lived in Poole for most of its life…..
#314
Parked for 6 years on grass or possibly gravel and weeds I think.
Rear bushes. Mostly self-explanatory. Not a fan of the Febi bushes for the hub as the metal is very thin making them likely to crush when they go in. I'll investigate the Febest versions, or spend the money on the genuine D3 items in the future. Fuel tank straps. They are attached to studs pressed in to the body. When removing these nuts one has to be extremely careful not to put too much torque on them as the studs will just spin in their holes and then you're going to have a very bad day. After soaking in WD40 for a couple of days, then cleaned with a wire brush and a pick, then soaked in WD40 for a bit longer, I'll screw a spare M8 nut on to clean up the thread. Once this goes on and off by hand, only then will I loosen the strap nut, as I know it'll come off cleanly. This is the sort of job where you need a 1/4" ratchet, maybe 3/8" max, so as not to put too much torque on anything. With the straps on the right hand side off, the tank drops just enough to get to the bolts holding the horribly rusty exhaust hanger Powdercoated exhaust hanger and tank straps, with new nuts. Much better ![]() |
#315
Is the hanger in second to last pic one piece? I ordered 2 but none of them are this big 😥
#316
That is great information! Did you just get the existing straps and hanger cleaned up and powder coated?
Audi S8 D2 2002 |
#317
I have a complete spare set so got them blasted and powdercoated in advance so I can just swap them over. That was the plan with the subframe too, which hasn't gone quite so well. |
#318
Hm, it looks like V8 hanger differs from V6, so i think i got the right one
#319
Ah yes, iirc the V6 only has one in that position, so #6 for the V6 is #12 for the V8.
#320
Doing the rear brake pipes while the subframe is off. The two unions by the tank are pretty crusty. One of these pipes is staying put, the other one is getting changed.
The brake hose bracket has completely corroded through which is vexing The top part of this should be attached to the body, but its just turned in to fluff This is the remaining stump of the bracket The solution will involve a new bracket and structural adhesive. |
