Old 20th March 2022, 06:59 PM
Subframe today, but I started by glueing the brake hose bracket on so that could be curing. The adhesive has a nominal strength on aluminium of 22N per mm². The bracket has an area of 616mm² which gives 13552N of holding force in ideal conditions, or 1.3 tons. I reckon that should hold a brake hose
New bolts. I've used the D3 toe adjustment bolts as they're only 4mm longer than the D2 ones. I got mk5 Golf camber bolts, but unfortunately they are missing 8mm of thread on the end so aren't quite long enough. The D3 camber bolts are 10mm too long, so I may have to just get the Febest ones.
The two long ones on the right are for the outer toe rod joint, which are from an Amarok, and 5mm longer than the D2 bolts. We probably should have an alternative parts thread where I can list all this...
All assembled
It was about this point where my phone battery died, so no more pics unfortunately. I had to swap the headlight level sensor, and made a new arm for that at the same point. The rear dampers are painted and back in too.
There are a couple of jobs left before putting it back in the car - the diff mount bolts were on back order so those need swapping, new camber bolts as noted, and a few other bits of hardware. I'd also like to get the brakes assembled while its sitting on pallets and nice and easy to get to.
Finally, I need to make some alignment sleeves to line it up with the rear mounting holes, as the tool I made when I did Ricky D's doesn't work with the D3 bushes. Those are 20mm inner diameter, whereas the locating holes are 21mm diameter, so I'll print up some simple sleeves for these. There's no load on them as they are purely used to line it up, and being printed there's no issue leaving them in place.
ID:	28065   Click image for larger version
ID:	28066   Click image for larger version
ID:	28067   Click image for larger version
ID:	28068   Click image for larger version
Old 20th March 2022, 07:39 PM
S81 S81 is offline
This is really pretty much a full refurbishment,are you looking at 300 plus hrs ?
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 21st March 2022, 10:11 AM
Ronin Ronin is offline
Nice touch with the carpet on pallets.
A typical workshop would probably just use 2 transmission stands or something and scratch the subframe.
Old 23rd March 2022, 03:13 PM
The time and effort to 'do it right'
I would have just stuck a rivnut in there and bolted it
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 23rd March 2022, 05:35 PM
Presumably Rivnuts etc are not aluminium. Is there therefore a potential for galvanic corrosion in future, or does your use of sealant insulate he different metals from each other?
Old 23rd March 2022, 08:44 PM
I have aluminium rivnuts where they are appropriate, and considered one here but I don't have a reference for what's behind this sheet metal so adhesive was the way to go.
Now covered in seam sealer
New fuel filter
The old one was dated 2002 so likely the original
This is the D3 camber bolt which is 10mm longer than it needs to be. Its ugly but it does the job.
ID:	28076   Click image for larger version
ID:	28077   Click image for larger version
ID:	28078   Click image for larger version
Old 26th March 2022, 07:17 AM
Changed at recommended intervals
I wonder what it looks like inside?
Paul
Gosport UK
Honda Jazz
Old 26th March 2022, 07:37 AM
They are usually a bit brown but nothing remarkable. I cut the Murple's filter open, which had 323000 miles on it was just a bit dark. No crud or blockages.
Some progress from last night - rear calipers painted to match the fronts
Printed alignment spacers to line the subframe up with the body. There's no load on these - they are simply there to hold everything in the right place while the bolts are done up.
Subframe complete and ready to go back on. I keep looking at this and wondering whether a Tesla motor would fit in it
Reassembly is the reversal of removal Position it in the right place on the pallet jack and lower the car on to it
Bolted back in
B-roll shot
A few bits to reconnect, but it should be back on its wheels today
ID:	28085   Click image for larger version
ID:	28086   Click image for larger version
ID:	28087   Click image for larger version
ID:	28088   Click image for larger version
ID:	28089   Click image for larger version
ID:	28090   Click image for larger version
ID:	28091   Click image for larger version
Old 26th March 2022, 09:20 AM
An S8 FE-E............ hmmmm call to action for someone I bet
Paul
Gosport UK
Honda Jazz
Old 29th March 2022, 07:47 PM
Are there alignment spacers used during first assembly? Just curious if the tolerance between the sleeve in the bush and the bolt is to allow for some 'lateral' adjustment to align the front and rear subframes or wheelbase lengths.
Paul
Gosport UK
Honda Jazz
