Hello my steering column has started acting up after i switched the ignition on and off quite quickly the steering wheel started moving when I turned the ignition off for the easy exit function but than when I instantly switched the ignition on again it stopped moving and will not move in or out now but still up and down same issue when using memory buttons moves fine up and down but no in and out I have replaced the control module but no difference next step I think will be lowering the entire column down and giving 12v directly to the adjustment motor. Has anyone encountered this issue or maybe have some input on possible source of the problem? Thanks in advance for the help
D2 A8L 4.2 AQF 4.2 LZ9W Ebony Black Pearl Fully electric rear seats D3 s8 front brakes s8 mirror housings 18x8 Avus 3 winter wheels PDC rear blinds Nav Electric steering wheel adjustment TPMS Leather pack 1 with retrofitted stitched leather lower dash panels folding auto dimming mirrors solar sunroof cold weather package CD changer double glazing all around memory seats passenger seat adjustment from rear seat Bose servotronic xenon plus headlights C5 Allroad 4.2 BAS 4.2 LZ6G Irish Green Metallic Bose RNS-E Rear Blinds folding auto dimming mirrors Heated MFSW with shift buttons PDC Recaros heated seats all around CD changer Nav B5 A4 STCC Edition AJL 1.8T Quattro Built engine GT28RS maxxecu Remote locking Trip computer Sport seats Eibach/Bilstein suspension Flexfuel D4 A8 4.2 TDI Previous Audis B7 S4 Avant B5 A4 Avant 1.8T B8 A5 SB 3.0tdi C5 A6 1.8T C5 Allroad 2.5 TDI |
Usually its the switch when the column won't move in and out
If the switch stopped working wouldn’t the column still move when i press the memory buttons?
I've no personal experience of this problem but a while ago I read a thread similar on a US site. Unfortunately I can't remember which site.
They were saying that constant use of the easy entry / exit feature will eventually work harden the cables and cause a break. Especially so with the extend and retract circuit. I have mine turned off so as to avoid the possibility of this issue.
Hi OP
did you ever get to the bottom of this? My steering column has stopped moving altogether - so no up/down or in/out, and it has been like that for a while. I checked the fuse for the steering column adjustment (I think it was a 25Amp), but it was fine. What is interesting is I don't recall the memory seats working either - I wonder if that is a pre-req? the seats do adjust electronically though when I adjust it using the buttons on the seat. thanks for any input.
Current: 2007 Audi A8 3.0 TDI SE Quattro - ![]() |
