Old 20th June 2022, 05:59 PM
Markiii Markiii is offline
interesting I thought the s8 red sachs were NLA?
Old 20th June 2022, 06:50 PM
4D0413031CD isn't listed on Tradition or ebay.
The B12 kit does sit the S8 at about stock ride height. Its made with B6 dampers rather than the B8s as far as I can tell - they certainly aren't any shorter than the stock Sachs units.
Old 20th June 2022, 07:48 PM
scottmgibb scottmgibb is offline
I am in the process of rebuilding my suspension with Bilstein B6 dampers. I am using the old springs, but have had them re-painted.
I used parts numbers 24-066785 & 24-026161 and got one pair from Autodoc and one pair from www.bilsteinsuspensionstore.co.uk (as that was the cheapest way). Cost just under £500 for all four.
Nowhere near to the point of driving the car though, so cannot tell you how they feel unfortunately!
Audi S8 D2 2002
Old 21st June 2022, 01:18 PM
anyone know if the top mounts are available? suspect the may also be past their best
Old 21st June 2022, 01:57 PM
https://www.ebay.co.uk/itm/334297127576
Old 22nd June 2022, 08:57 AM
thanks MJ are they the same front and rear?
Old 22nd June 2022, 09:18 AM
Those are fronts. Rears are not available, but luckily don't tend to wear out.
4D0512169D if you want to try and find some - I've previously drawn a blank but its always worth poking around just in case
