Can they be replaced separately or it's whole assembly only?
In theory, you can replace them but I haven't seen any for sale (although not looked specifically).
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
I understand they are not cheap new.
If the shocks were worn I suspect it would be softer but bouncier. They could go hard if it was electrical problem and valve stayed completely closed all the time but it happening to all shocks at the same time is unlikely. Get somebody familiar with the D3 to have a look.
Wheel size and tyre make, model and pressure can make a big difference. Also for some aftermarket suspension arms the bushes transfer more shock than OEM so could be that if they have been changed. Not sure if track rod ends for D3 have rubber inserts but on D2 and C5 they do and it makes noticeable difference if using aftermarket solid TREs without rubber insert.
Is check the ride height, relatively simple to lower using VCDS and could explain why it's better in lift mode?
Bushes look ok, I have ordered new drop links but I'm very certain it isn't that. ![]() If I remove the assembly, any way of testing the shock absorbers? Wouldn't want to spend £700 unnecessarily. Last edited by hunker7; 25th June 2022 at 08:19 PM. |
So I put it in auto for whatever reason and car seems a lot more comfortable. What could cause it to go hard on comfort and not auto?
