Old 24th February 2009, 09:52 PM
And the next stupid question.. You've tested all the switches on the lights themselves?
It is possible that he previous owner has just let all the bulbs blow over the years though...
Old 26th February 2009, 02:05 PM
Indeedy - Can you make them work manually, ie is it an automatic lighting failure, or in fact are the bulbs completely dead ?...
Old 27th February 2009, 12:11 AM
moono501
Guest
Posts: n/a
Wow, thanks everyone. These replies are really helpful. I've checked fuses, switches etc but not the V94 to the central locking unit. Er.. where will I find it? I'll put up a pic/pics of the car as soon as I've got some to post, promise (don't need much of an excuse to show it off!).
Old 27th February 2009, 12:17 PM
Ska's Avatar
Ska Ska is offline
V94 is proly with the central locking pump in the n/s rear quarter panel near the aerial; boot trim, CD changer etc needs to be removed which is fairly easy.
Old 23rd September 2009, 07:21 AM
slowwy1 slowwy1 is offline
Did you manage to get to the bottom of this? I traced the wires to the boot lights and they only go to the CL pump in the back. The connection there seemed fine though. There is a good GND connection to the lights, it's the 12V that are missing. Can the lights be coded differently using VAGCOM?
Old 23rd January 2010, 12:26 PM
It turns out that it was a 10A blown fuse (1 brown for central locking). I suspect something had shorted it and blown it when I had tried to check, most likely the lights in the boot. All working now.
