Old 5th July 2022, 10:09 AM
Default Things you didn't know you had.......
Following my S8 being "fettled" by the D2 Doctor I decided it was time to sort through my piles of assorted Audi parts and related materials.
There's a lot that can go and some I'll keep as spares "just in case".
First things I found were an old TV tuner and CD changer, I think I've also got some brackets for these buried in my garage...
- 4D0 919 146 TV-Diversity-Receiver (Fuba)
- 4B0 035 111A CD-CHANGER (Matsu****a)
Any use to anyone, otherwise I'll scrap them. Need to power up the CD Changer first to check it's empty...... (it was)
Old 5th July 2022, 10:30 AM
I've also got a Facelift Throttle Position Sensor (the unit on the throttle pedal) which I bought (from our sponsors) when I was having odd performance issues.
That turned out in the end to be a poorly-adjusted brake pedal switch!
- 028907475BD A8 D2 FL Accelerator Potentiometer (used)
I'll keep this, but if anyone needs one, beer money (or charity donation) plus P&P will do fine.
As part of the same performance issue I also replaced the fuel pressure regulator and have the old one which is presumably still fine.
- 0280 160 575 (Bosch)
Old 5th July 2022, 11:28 AM
Totally inappropriate and surplus badging found on the boot of my current S8 at purchase.
And I hadn't noticed...... Anyone want it for nefarious purposes?
