Old 7th December 2022, 09:26 PM
You can't map it out with VCDS - that can only change the coding whereas to permanently remove it the ECU needs to be flashed with new code, the same as a traditional remap.
It can be DIY'ed using Nefmoto software and a generic OBDII to USB cable, but that does carry some risk as it has the potential to brick the ECU if it doesn't work or goes wrong.
The easiest solution is to just fix the vacuum pipes to the solenoid and the two SAI valves so the system works again. There's not really any advantage to mapping it out when you still have all the hardware in place and don't plan to remove it. Its more the remap allows the hardware to all go away.
Old 8th December 2022, 06:14 AM
Thanks Michaela. Do you have a photo of the vacuum pipes so that I can locate them and fix the problem?
Old 8th December 2022, 06:40 AM
Ronin Ronin is offline
Vacuum line schematics are in the engine service manuals in the thread linked below. I've used them myself to rebuild mine. A roll of vacuum hose is £15ish on eBay
http://forum.a8parts.co.uk/showthread.php?t=9345
Old 8th December 2022, 08:47 AM
That was quick -thanks loads!
Old 8th December 2022, 09:47 AM
The only pics I could get of this stuff is either in the bin or on the workshop floor Better to go off the manuals
Old 8th December 2022, 11:38 AM
Unfortunately, I seem to thick to find the right page in the manuals
Old 8th December 2022, 12:03 PM
I can't find them either
