Old 17th January 2023, 09:34 PM
Thanks for checking.
Old 18th January 2023, 06:56 AM
Me too please PM sent.
Updated list:
Tintin
Hpsauce
MJ
David'S8
monkeyboyuk
The Laird
RICKY D
Zip
Sit down, Waldo
Spanker X5
Conan the Librarian
Old 18th January 2023, 02:09 PM
Ronin Ronin is offline
Updated list:
Tintin
Hpsauce
MJ x7
David'S8
monkeyboyuk
The Laird
RICKY D
Zip
Sit down, Waldo
Spanker X5
Conan the Librarian
Neil x3
Old 18th January 2023, 02:41 PM
Updated list:
Tintin
Hpsauce
MJ x7
David'S8
monkeyboyuk
The Laird
RICKY D
Zip
Sit down, Waldo
Spanker x5
Conan the Librarian
Architex x2
Thus far we've been mostly talking about the whole switch panel, but for those who are feeling slightly more adventurous (and want to save on postage) the switch itself is easily removed. Once the panel is out and unplugged, you'll see two little levers on the back of the switch. Pull these away from the edge of the switch while maintaining light pressure on the front of the switch and it will pop out of the panel
By the way, to unplug the connector I would recommend levering the two tangs off with a small flat screwdriver, rather than just pulling it. The connector tangs are rather stronger than the tabs holding the switch together, so pulling on it presents a significant chance of tearing the switch in half!
Old 18th January 2023, 04:29 PM
Good point there MJ, I remember having that apart for some reason ages ago.
I'll probably do that anyway, my mounting panel is in reasonable condition and I'll just clean it up myself.
(MOT booked for next Tuesday so I probably won't post it until after that)
Old 18th January 2023, 04:43 PM
Yes, its cheaper to post it with the plasic shroud removed, I just didn't want anyone to break locking tabs or cause any other damage when removing it so i didn't mention it
Old 18th January 2023, 04:52 PM
Spanker's Avatar
Spanker Spanker is offline
Yes. 22yr old plastic tabs can be a little brittle and fall apart without even touching them
Dean
Old 18th January 2023, 05:19 PM
Still time to be added to the list?
My lights are on but the on off switch doesn't "on/off"
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 18th January 2023, 06:15 PM
Added!
Address and payment details will be sent to everyone tomorrow as it's the last day to sign up.
Tintin
Hpsauce
MJ
David'S8
monkeyboyuk
The Laird
RICKY D
Zip
Sit down, Waldo
Spanker X5
Conan the Librarian
Strummagnet
Old 19th January 2023, 05:36 AM
Neil and Architex have disappeared from the list. Is that intentional? I know they’re the same person, but both versions have gone!
