Old 26th January 2023, 02:57 PM
I have some bad chips on the mounting door insert which I want to address. I found that the closest match in colour and mattness (for those with a "Twist" interior) was Halfords Camouflage Spray Paint - Khaki ultra matt. Today I tried it on a plastic surface and its looks good - not exact but very close and has the right matt look. Its too cold to spray paint even in the garage today but I'll try it out on the insert and post some piccies. (Its certainly better than the scratched item and, being isolated from other similar coloured items, will be be hard to see any difference)
Old 26th January 2023, 03:01 PM
David, I've just touched in my scratches with a tiny thin brush using grey car primer! Actually hid them surprisingly well.
Depending on the damage, try spraying into a small cup/cap and collecting the paint as liquid then using a fine brush to fill in, rather than spraying the whole thing.
Old 26th January 2023, 03:20 PM
Andrew, I thought yours was Twist too? I have thought about the spray/touch up method and used it elsewhere (wheel centre caps to be precise) so that might be a method Ill try first
Old 26th January 2023, 03:37 PM
Yes it is, but the scratches show up as white. Tiny amounts of grey primer are actually pretty invisible in comparison.
I'll find the right colour eventually and go over them, but it's surprisingly unnoticeable back in situ.
Old 26th January 2023, 05:03 PM
The grey boxes are the same shade...
If the contrast between twist and primer is small enough, in a small area, the brain just fills in the difference
Old 26th January 2023, 06:21 PM
Ronin Ronin is offline
Quick update:
I haven now received the vast majority of switches+ replacement switch from Prestige.
I will start doing them tomorrow and send out as many as possible on Saturday.
Tracking number will be provided via PM
Old 26th January 2023, 07:18 PM
I’m trying to send mine to you (I’ve paid) but Royal Mail want a mobile number. Can you send that by PM please?
Old 28th January 2023, 09:23 AM
Very true.
In this photo, close up, you can see some of the larger touched up patches, plus one small whiter chip I missed.
In reality, from the drivers seat, you don't notice anything amiss.
Much more distressing is the mangled alcantara, due to an agressive valeter before my ownership:
