#41
Not enough people have the necessary skills (me!) and/or tools and/or workshop space
#42
Looking forward to the update on the poly bushes. Great work.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
#43
What is the process of aligning the rear subframe
Are there pins or something as a guide like for the front subframe?
#44
Yes there are 2 of them, i think MikkiJayne made some.
#45
When I had my car aligned after I did all the work, the position of the front subframe was adjusted slightly to balance out the camber. I guess if you used locating pins then you would not be able to do this (and there is no other stock way of adjusting this). Of course if I had used locating pins then maybe it would not have needed to be adjusted…?!
Audi S8 D2 2002 |
#46
The locating pins for the front and are just to get it in the factory default position. They almost always need moving afterwards to get camber and caster correct, so if yours just needed slight adjustment you must have eyeballed it pretty well The pins come out afterwards.
The rear doesn't have pins. It has sockets in the rear mount hardpoints, but the sockets are slightly larger than the hole in the bush so I'm not quite sure what the factory tool looked like for these. I 3d print one-use bushings each time I do the job, and they just stay in place sandwiched between the subframe and the body. Aftermarket bushes that I've seen tend to be even smaller than the factory ones so there's no way to get a tool out again afterwards. |
#47
NLA rear trailing arm shock absorber bush is back in stock on autodoc. I suggest anyone planning to do a subframe refurb to get 2 before they dissapear again:
https://www.autodoc.co.uk/febest/14133184 |
#48
