Go Back   A8 Parts Forum > A8 D2 > D2 - Common Faults
D2 - Common Faults Quick links to all known common faults and their solutions
Old 3rd March 2023, 01:24 PM
Depends if yours is Pre-facelift with a real throttle cable or facelift "fly-by-wire".
PF has a module deep inside the ECU box under the bonnet, FL it's just part of the standard engine ECU software so has no separate module.
As ever, always requested, add details of your vehicle to your signature please, it makes answering queries such as this so much easier.
Old 3rd March 2023, 03:32 PM
donp38 donp38 is offline
Many thanks HPsource..
Bugger....so no real easy fix then!
Mine is a facelift for fly by wire...
Can anyone recommend a specialist that can take care of this?
What is needed now?
New ECU?
Old 3rd March 2023, 04:04 PM
It's just ECU, stalk and wires for FL. If the engine runs it cannot be faulty ECU as it's very unlikely to fail in such a way that car still runs but CC does not work. It's usually just dirty/oxidised contacts in the stalk. Soakong in contact cleaner and exercising vigorously sometimes can bring it back. Cannot remember if there was an option to have D2 without CC so could be ECU coding to enable/disable CC
Old 3rd March 2023, 04:07 PM
Interesting.
Had it driving along with OBD connected.
Can see the switch switching every time but nothing actually happening re CC working..
Old 3rd March 2023, 04:14 PM
Check CC is enabled in the ECU coding. Details are on the Ross Tech web site.
Old 3rd March 2023, 05:14 PM
It is actually switched on? The slider on the stalk...... (which is also the "increase speed" function)
Could be the slider switch is faulty, depending which switch signals you're seeing. The button on the end is only for "set" and "reduce speed" functions.
And you don't need to be driving to check the switch operation, at least with full VCDS as your OBD tool.
Old 3rd March 2023, 08:19 PM
Many thanks both.
I will check and come back to you.
Old 3rd March 2023, 09:43 PM
Do you have any error codes? Anything to do with pedals, gearbox, throttle body, missfires or MAF will stop CC from working
