Engine start
Hi all I am looking for help. I own a8 d3 2007 3.0tdi my issue is that I cannot put car just for ignition, like fir scanning. As soon I press start button engine start even without brake pedal pressed. I change for bew beake switch, there is no fault in vcds, I try with key also as soon as you move key to right engine start again without brake pedal. Measuring block shows brake switch working and showing pressure also. Could someone help me please 🙏
How about putting gearstick in Drive, that should stop it from starting
Thank you I will try that. But I eventually I will need permanent solution so trying to sort this out
Is it possible the brake pedal interlock has been disabled in coding? Might explain it.....
The D3 has an engine authorisation and start module doesn't it? Not my specialist subject obvs, but I'm sure I've seen it in the diagrams. Maybe try and get a scan of that - perhaps it is faulty and does an engine start on power-up instead of actually waiting for the start command?
When my D2 S8 (OK a different, earlier and simpler model) had problems starting it was identified as a faulty F125 switch. Shorting out the relevant relay that inhibits inappropriate starting, overcame the problem. BUT having done that it was possible to start the car with the gear selector in any position, not that I did. As MJ notes, it's a more complex system on the D3, but testing that, if you dare, might help pinpoint the issue.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 23rd March 2023 at 09:25 AM. |
Remember replying to this a while ago on one of the Facebook groups.
It might possibly be the ignition switch itself being faulty. The part number is 3D0905865H, item #2 in the attached image. If you could source one from a seller that allows returns, you could try that and if the problem persists, it would eliminate that from the equation and you could return it for a refund. Can someone confirm something about the push button start. I never used it on mine, but doesn't the key need to be in the ignition for that to work, with putting the key in unlocking the steering column?
I have keyless start system. But even when I put the key to ignition still thos same just touch to right and car start
