Old 11th April 2023, 09:33 PM
One year I forgot and the weather was awful, complete with a deep flood only a couple of hundred yards from the test centre. Fortunately the technician had the common sense to "rev the nuts off it" on the ramp when he realised it had got cold and wet on the way there, so it passed.
The heavens opened up here on my way to the test station today and i only travelled a few miles. Longer run tomorrow..
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 13th April 2023, 11:15 AM
Well the car went back after a 'very spirited' 30 mile drive. Re-test and still failed.
The Tester wouldnt "rev the nuts out of it" as its 'not policy' but suggested a more mechanically sympathetic organisation might be a better bet.
Anything obvious I should (with my limited skill set) look at? I do have VCDS lite.
Paul
Gosport UK
Honda Jazz
Old 13th April 2023, 01:17 PM
Ronin Ronin is offline
Befriend a dodgy MOT tester, preferably one that does all the taxi drivers where you live
Old 13th April 2023, 03:35 PM
Mr Ronin
I have spoken to a 'sympathetic' MOT tester today who has managed to fit me in for Monday at the earliest.
Paul
Gosport UK
Honda Jazz
Old 13th April 2023, 05:11 PM
My MoT guys gently let off the throttle after the fast idle test to allow everything to stabilise gently. They take it from ~2500-3000 rpm back to idle over about 5-10 seconds rather than just taking the foot straight off. That allows the closed-loop control to sort everything out by the time the machine takes its reading. If you just close the throttle and hit the test button the mixture can still be a bit rich and cause this sort of problem, on older cats.
Old 17th April 2023, 04:27 PM
Well MOT day again. I explained the above guidance and the MOT tester understood what needed to be done.
He had to adjust the main beam.
Passed with zero advisories.
Paul
Gosport UK
Honda Jazz
Old 17th April 2023, 04:44 PM
sarg sarg is offline
Great news
My MOT tester told me his rule of thumb is whether the car is likely to kill you or somebody else, if not then it passes.
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 17th April 2023, 08:23 PM
Great news
But surely, one look at the driver and it'd be a fail
Old 18th April 2023, 04:33 PM
but surely, one look at the driver and it'd be a fail :rofl:
:rofl:
Old 18th April 2023, 10:10 PM
Naughty Nick!
Shades of pot and kettle.
But then I can't talk.
