#121
Yes, in the sense that it had totally failed and I didn't want to buy a ludicrously expensive replacement from Audi then pay extra to get it sprayed the right colour.
I think it cost about £10. This was before the days of A8parts, or certainly before I knew of them or this forum. I actually fed the cable from the puck antenna under the boot rim seal then up the cable run into the boot lid and joined into the existing wiring there. Might seem a bit weird, but it was reasonably accessible and there was a connector linking to the aerial on the boot lid. Getting the boot lid inside trim off is pretty easy and you can then access everything fairly simply. So I didn't have to cut any cables or go rummaging in the cabin behind trims and under carpets looking for cable runs. I think I needed an adapter of some sort as, inevitably, Audi use different coax connectors to the rest of the GPS world. ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 10th May 2023 at 07:54 AM. |
#122
It ended up going here as there was a perfectly sized cut in sound proofing there from the factory, lol:
![]() This is a TPMS system i installed for another forum member on the weekend too, it even shows spare tyre pressure: ![]() Last edited by Ronin; 24th May 2023 at 04:11 PM. |
#123
40psi??
Paul Gosport UK ________________________ Polestar 2 Long Range Audi S8 2002 https://forum.a8parts.co.uk//showthread.php?t=16187 Honda Jazz Harley Low Rider 107 Stage 2 Harley Sportster 1200 |
#124
The pic was taken during installation, it has been changed to bar now and is working ok, providing interesting insights to how tyres heat up on a drive, it's also set to trigger a warning if tyre goes flat.
#125
It over-reads by 2psi, ish.
#126
Would you rather have it over read by 2psi and show temperatures or.... strip the whole interior and wheel arches out to install the ancient oem audi tpms system that doesn't even display the pressures or temperatures and at some point will die due to water ingress?
![]() At least the android TPMS system is installed in the center console, so you will spot the leak way before water level reaches that high ![]() |
