Old 25th June 2023, 07:27 PM
Ronin Ronin is offline
Default Heating system flush
It was worth it, i highly reccomend
I also replaced the heating valve block/motor
If someone plans on doing this, it took me about 9h start to finish with no breaks.
Result = I now have a car with working heat and AC
Old 30th June 2023, 04:59 PM
Smile
Did you follow the manual? Any tips / handy hints along the way?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Audi S8 2002 FE Avus Silver / Extended Red Leather. https://forum.a8parts.co.uk//showthread.php?t=16187
Honda Jazz
Old 1st July 2023, 09:52 PM
One tip I can give is to start flushing with a very low pressure and wait for water to start coming out the other end, once it starts coming out then you can safely increase it.
Also you will find quite a few corroded connectors in the ECU box so have contact cleaner ready.
Old 2nd July 2023, 07:17 PM
Also this diagram is useful:
I flushed each heater core in 2 directions as well.
