Old 19th July 2023, 02:18 PM
Default HVAC Fault 01274
It also says: Air flow flap positioning motor (v71). 41-10 blocked or no voltage - intermittent.
Can anyone provide a translation so I know what to look for?
Thanks
Old 19th July 2023, 02:42 PM
01274 - Air Flow Flap Positioning Motor (V71): Faulty
Possible Causes
Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty
Positioning Air Flow Flap Positioning Motor (V71) blocked
Positioning Air Flow Flap Positioning Motor (V71) faulty
Possible Solutions
Check Air Flow Flap Positioning Motor (V71)
See Measuring Value Blocks (MVB)
Perform Output Test
Perform Basic Setting
Check/Repair Wiring and Connectors
Try running basic settings in the first instance, and see if the fault reappears. If lucky it will resolve itself, but if not will be a case of accessing it to check if the motor has failed or if there's a related mechanical fault in a linkage somewhere
Old 19th July 2023, 03:39 PM
Thanks Adrian. I'll give that a try
Old 26th September 2023, 01:21 PM
And it worked! Thanks so much for that, Adrian.
