D2 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
The very common no-start condition
![]() I've gone through many of the basics, but some things confuse me. For example, I do not see the Check Engine Light (CEL) at any point with the key in ON or RUN, which means there shouldn't be power to the ECU and/or the crank sensor is failing. However, if I put starting fluid in the intake, the car will start! I need to do a little bit more reading here, but today I will probably check the ebox in the engine bay and verify for moisture, and check fuses and modules there. Oh, and the battery is a brand new, proper size (huge!) OEM Audi battery. The fact the car started with starting fluid made me switch to checking the fuel system. I've checked the fuel pump fuse, the fuel pump relay, and I'm getting a constant stream of fuel to the fuel rail. But since the car is not starting, I'm unsure if I'm getting enough pressure. That's why I'd like to put a gauge in the fuel rail. I've been doing a lot of reading, and I'm also going to add about 5 gallons of petrol ![]()
Audi V8 Quattro Original 5speed - Black/Black Audi S8 - Avus/Oxblood Audi S8 - Cashmere/Twist BMW 850i - Red 6speed BMW 850Csi - Red 6speed Ford Thunderbird x 3 Supercharged & 5speeds Mustang convertible Range Rover Autobiography - BRG/English Tan |
