Old 20th March 2024, 12:08 PM
Well I managed to pull out the broken part by simply removing the throttle body. It looks like a clean break so I am confident there are no other bits floating around.
Still not sure of my route forward yet. It's not a big job removing and replacing the intake Manifold so I'm considering fitting it back as is to see how she runs.
If I could get a new one for around £1500 I'd buy it but I just can't bring myself to spend £2500 which is what Audi quoted me, with a 10% discount.
Who knew these cars would be so expensive to maintain eh? Mmmmm.... Actually as I think about it, I think we all know that.
ID:	30173   Click image for larger version
ID:	30174   Click image for larger version
Audi S8 D2 2002 88k mls
Old 20th March 2024, 05:04 PM
Spanker's Avatar
Spanker Spanker is offline
You could consider this if you find it suitable:
https://www.ebay.de/itm/196296607848
Dean
Old 20th March 2024, 05:06 PM
I don't think it's ideal to run it with one flap missing, either have them all or remove all. That cylinder will be getting more or less air compared to other cylinders depending on rpm but the same amount of fuel as rest on that bank so could be running lean or rich and cause damage to the engine if too lean or cats and O2 sensors if too rich.
Old 20th March 2024, 06:36 PM
I've been trying to wrap my head around what effect having one long runner and 7 short ones would have on the engine. I honestly have no idea but I did think that each cylinders fuel requirements was determined individually. I could very well be wrong here but my understanding was that the exhaust manifold is divided into 4 separate tubes internally so that the o2 sensor and ecu can determine which cylinder has just exhausted and thus trim fuel accordingly.
I've ordered a used unit on the evil bay and will see what it is like when it turns up. I may still end up making a good one from the two but let's see what happens.
I'll keep you all posted and if I end up stripping them down I'll post my progress with a bit of a how too guide.
Cheers Frank
Old 20th March 2024, 07:25 PM
Cheers Frank
O2 sensors do not work that fast they just measure average and trim fuel for whole bank, you can expect response time 0.5-2sec, in that time each cylinder in idle fires 5-10 times. Plus the glasses already in exhaust are mixing with incoming glasses.
Old 20th March 2024, 08:08 PM
Thanks Dean for the link.
It does look like it's been drilled for LPG though.
Old 21st March 2024, 07:47 AM
Spanker's Avatar
Good spot. I should have read the description as it states that there too.
Dean
Old 21st March 2024, 03:55 PM
Just ordered this one from the US. Gonna be a pain as I had to use a freight forwarding company (shipito) as they wouldn't ship to the UK. I think it will work out at about £1500 landed which was about my limit.
