Go Back   A8 Parts Forum > A8 D4 > D4 - Interior Electrics
D4 - Interior Electrics Airbags, Sensors, climate modules, instrument clusters, switches etc
Old 30th May 2024, 10:07 AM
Horrgakx Horrgakx is offline
Default Using the SIM card slot UK
I'm trying to get my head around the SIM slot, Audi cordless phone in the console, and using my own phone hands-free.
If I put a SIM in the slot, isn't it useless anyway as 3G is being turned off?
A8L W12 (D4 2015)
Old 6th June 2024, 08:27 PM
Bump - anyone?
A8L W12 (D4 2015)
Old 6th June 2024, 08:29 PM
I have a SIM in mine and phones used in the car can then access the outside via the cars, more powerful, arial.
Old 6th June 2024, 08:30 PM
Thanks - so you can use your own mobile to route through the SIM in the car to make calls? (and data?) How does that work?
A8L W12 (D4 2015)
Old 9th June 2024, 05:40 PM
Yes, exactly so. When you've inserted your SIM, open the part of your phone that finds available internet connections and select your car. It will be called Audi and some additional characters. I can't recall the exact procedure but it is intuitive and takes you where you need to go. Good luck.
Old 9th June 2024, 05:43 PM
Thanks.
3G is already switched off and so is unavailable in the UK. I assume the service the car offers is 3G only?
A8L W12 (D4 2015)
Old 10th June 2024, 09:11 PM
I need to check. I can see that 3G is being switched off in the UK but I thought my car was still connecting. Hmm
Old 11th June 2024, 07:50 AM
It depends on your network! According to OFCOM (who ought to know):
Vodafone completed its switch-off in early 2024.
EE completed its switch-off in early 2024.
Three expects to switch-off by the end of 2024.
O2 is planning to switch-off in 2025.
I certainly regularly get 3G on my phone on Giffgaff (O2).
Old 11th June 2024, 11:29 AM
Mee too. I am with Tesco(O2) on the phone and there are some areas around here that do not have 4G coverage(or signal is too weak) and it drops down to 3G. Or sometimes 4G is so slow because of weak signal, less than 1mbps that I manually force it to 3G and get 4-10mbps over 3G in the same spot.
I don't know what network Tesla use, it also often drop down to 3G but it's almost unusably slow when it does that.
Old 2nd July 2024, 01:22 PM
I put a Vodafone SIM in my car for a trial basis but it's useless. The car DOES get a 2G signal which is good enough for weather reports and text-based stuff, but Google Earth doesn't load up on the Nav system and nothing else seems to work. So I've cancelled the SIM.
NavMan says that the Traffic info isn't available any more anyway due to Trafficmaster discontinuing the service. A fuller post I made is here; https://forum.a8parts.co.uk/showthread.php?t=17265
A8L W12 (D4 2015)
